Results 1 to 10 of 32
Thread: Mounting a Tablet on dash
    Mar 2015
    Port Macquarie, NSW
    Does anyone have photos that they can post here showing how they mounted a tablet to the dash of their vehicle?
    I have a 10.1" Asus tablet fitted to a RAM Tab-Tite holder which for a short while I used to attach to the windscreen of our previous vehicle with a sturdy RAM suction cup. It was located in the middle of the dash - ie between the passenger and driver, but it was too high on the dash and blocked a good part of my forward vision - apart from possibly being against the law, so I removed it. I also tried the holder that clips into the air vents - not stable for a 10.1" tablet and the rod that bolts to the base of the front passenger seat with the tablet sitting on top - again very unstable on rough roads.
    I haven't tried installing the tablet in our new TDV6 MY15 yet as it is still at the mechanics being fitted with stuff. So I am not sure if placing the RAM mount on the dash will be obstructive or not.
    Has anyone found a solution?
    ps: I don't want to go any smaller with the size of the Tablet.
    Aug 2014
    SW Victoria
    Try google for Hold my Phone. They have quite an array of mounts, not sure if suitable for the weight and size of a tablet but worth a look.
    Cheers Alan
    Mar 2015
    Port Macquarie, NSW
    I have the mount. I just want to see where others have attached it. Also want to see if anyone else has placed it on top of the dash in the middle and whether it obstructs the driver's view.
    Quote Originally Posted by pprass View Post
    Make a cardboard dummy and try it out.
    2003 D2a Auto TD5 good Landy gone
    2015 D4 probably the most amazing yet, why get a RR?
    Jul 2014
    Sydney NSW
    I use a windscreen suction RAM mount for my Galaxy tab 10.1, it works well and doesn't really obstruct my vision at all.
    I'd send a photo but I've taken it off as I'm having the windscreen replaced tomorrow.
    Once that's sorted I'll post a photo.
    Bunbury, WA
    With the 8 speeds lack of a shift lever, there is a huge amount of real estate to mount a tablet down lower down. I have a 7" tablet in a RAM mount mounted on a flat steel bracket I made that bolts to the front seat bases. I have a small RAM mount that I can swap to use with my phone.
    I had the tablet mounted up higher in my old D2a, but I could not find anywhere suitable high up to mount it on the D4, both in terms of suitable to see without undue obstruction of the dash and something to mount it to.
    Have fun.
    Mar 2015
    Port Macquarie, NSW
    Quote Originally Posted by drelectro View Post
    I use a windscreen suction RAM mount for my Galaxy tab 10.1, it works well and doesn't really obstruct my vision at all...
    Do you have it mounted on the dash between the passenger and the driver?
    Mar 2015
    Port Macquarie, NSW
    Quote Originally Posted by cjc_td5 View Post
    ...I have a 7" tablet in a RAM mount mounted on a flat steel bracket I made that bolts to the front seat bases...
    Interesting set up Chris. Does it not get the shakes when going over rough surfaces?
    I used to have mine low down about the height of your set up on our previous vehicle (Nissan Patrol), but found that I had to take my eyes off the road for too long - ie just a second or two, but still the switching back and forth was a little disconcerting - especially for the passengers
    Bunbury, WA
    The phone is rock solid in its smaller mount, I haven't checked the larger tablet on a decent rough road yet. I would prefer it mounted higher up but there is no space without obstructing the touch screen or vision over the dash.
    Aug 2010
    I use a windscreen mounted bracket which suits 7 - 8" tablets, I wouldn't go any larger than that up there.
    It's great not to have to look down to check the map.
    2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
