Results 1 to 4 of 4
Thread: 2007 D3 SE Petrol - Fuel Pump Problem..
    Feb 2010
    Hi All
    Driving along yesterday and engine suddenly cut out, pulled over and she cranks over all 100% but just will not fire up.
    Got it home and did the following:
    • Put 5L of fuel into tank to make sure there was petrol and it was not just a faulty gauge (shows full) - no luck
    • Checked F1 - 25A Fuse - OK
    • Swapped Relay R8 with another and checked that Relay "clicks" when ignition put into position II - OK
    • Undone air intake and squirted a little fuel into the engine while cranking it - engine fire up and then stops - so my problem is not on the electrical or ignition side.
    Having done all this I think the fuel pump it stuffed.
    Pain in the backside dropping the tank and I do not want to layout $$ for a new pump unless I am 100% sure.
    Anyone else have any suggestions of something else to check?
    Harry
    RichardK is offline ChatterBox Silver Subscriber
    Western Australia
    That will be the fuel pump or blocked fuel filter, no fuel is getting to the engine
    RichardK
    Series IV Matrix Offroad Camper following our Discovery 3 with E Diff, BAS Remap, Mitch Hitch, Uniden UHF, Codan NGT HF, Masten TPMS, Proquip Compressor Guard, ARB Winch Bar, Milemarker Hydraulic Winch, 4x4 Intelligence Rear Wheel Carrier, VMS GPS with Rear Camera,
    Feb 2010
    Problem Solved - was a stuck fuel gauge showing full which made me run out of petrol
    Phoned a really helpful guy at McLean Motors (Thanks Mate) and he suggested that I put more petrol in the tank!!
    Apparently 5 L is not enough after you have run out so I added another 15L and away she went - don't ask me why but it worked!!
    SWMBO will never ever, never , never let me live this down..$ 120 for the tow and a bruised ego and were back on the road!!
    Note to self - start resetting the tripmeter when I fill up as a backup to the gauge.
    Western Australia
    Must admit I was puzzled when you said guage was full and you pit 5 litres in
    RichardK
