Thread: Chain lube.
    St Helena,Melbourne
    1.13 MB
    Chain lube.
    Almost finished the can of chain wax i bought must be 10 years ago, whats a good lube to use these days ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    May 2009
    Tatura, Vic
    I just use any brand that the local motor bike shop sells.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Dec 2009
    Hampton Park
    I know it's a bit late but,
    I have found that the ceramic chain oil is ok, just messy as it is white and shows up anywhere it flings to, very noticably. It also attracted a lot of crud to the chain
    Motul non- fling has proved to be good, just a pain oiling the chain all the time.
    One thing that I did get a while back was an attachment for the little plastic tube that sprays both sides of the chain at once. I got it off ebay($5, overpriced for what it is, but bloody handy).
    Suzuki recommends heavy(90w) oil. There is a bit of an issue with oil fling but it works so much better than the pressure pack stuff. The rear will just about freewheel on the stand once the chain has been oiled. I have been using Penrite 75w-90. It works really well, you just need to wipe the chain down well after oiling.
    Also, I have installed and am using a Motobriiz wind oiler, it uses the 75w90. Still in the testing phase at the moment but it uses air pressure to operate the oiling system for the chain. I will give an update in 6 months or so about how it is going. At the time, it was an Ebay special too good not to at least give a try.
    Jason
    Free Again Thanks Dan
    I use this set and forget very and i mean very light sling if any when you set it up right
    Cameleon Oiler - Home
    Avoca Beach
    Lucas chain lube is a very viscous oil with Mos2.
    The chain on my Honda 900 Hornet had 42KK on it when I sold it with minimal wear, with cleaning down each Saturday and re oiling.
    Regards Philip A
    Australia
    I had been using Rock Oil Chain Wax for years. I just bought some Yamaha branded Synthetic lube which flings a bit more than the Rock Oil but seems ok.
    Back down the hill.
    Chain, isn't that what you pull to flush an old toilet?
