Results 1 to 9 of 9
Thread: Durable Mud Flaps for a D4
    Sep 2014
    Nornalup
    Well, ripped another mud flap to bits. Wouldn't pay the money for the OEM ones which looked too brittle and put on a set of Chinese copies ($40 landed). Not so brittle but still plastic fantastic. I suppose at the at price I should buy a dozen sets. But is there an alternative? Something more rubbery?
    14MYD4 HSE SDV6
    Active Rear Diff, Snorkel, Outback Wheel Carrier, Outback Fuel Tank, OL BullBar, LLAMS, Fyrlyt, Domin8r Winch, Drifta Drawers, MSA Drop-slide, Frontrunner rack, Cargo Barrier, Codan 9323 HF, Traxide.
    "The North Remembers"
    Aussie Expat in NZ
    Might not be the look you are going for but went through a constant flow of the regular genuine and aftermarket flaps until I make some custom out of the stuff that the rally cars use. I got it on ebay.. There are lots of pre-cut stuff that may be of varying quality so I just purchased a roll of it cut 30cm wide and made it up to suit.
    The other trick is to stop them from getting caught under the tire when you are reversing - I think this is what destroys them for most people. I used a chain from a hardware store for mine. Doing this now may keep your current ones attached for a long time!
    Bunbury, WA
    Hi Boggs.
    Search "D4 Mudflaps" in the D3/4 area for an extensive thread on this, including my install.
    Sorry, I can't link the thread on my phone....
    Sent from my HTC One XL using AULRO mobile app
    Feb 2010
    Mount Martha
    Quote Originally Posted by Boggs View Post
    Hi Boggs,
    Check out this thread....http://www.aulro.com/afvb/d3-d4-rrs/...k-sliders.html
    Cheers, Craig
    Sep 2014
    Nornalup
    [QUOTE=Disco4SE;2366298]Hi Boggs,
    Great!.. I was thinking similar.. always helps when the sometimes random wanderings of my mind are proven to be sound when someone has already trodden the path with success!
    14MYD4 HSE SDV6
    Feb 2012
    Darwin
    Another thread link - D4 Mudflaps. Shows the defender ones on a D4.
    http://www.aulro.com/afvb/d3-d4-rrs/...-mudflaps.html
    Cheers, Mungus.
    _________________
    MY14D4HSE, Nara Bronze, E-Diff, Vision Assist, Surround Cameras, LLAMS, ProSpeed Sliders/Compressor plate, Mitch Hitch,
    ARB Summit Bar, Runva 11XP, Traxide D3-DU, GOE Comp. Rims, D697 265/60R18, Rijidij RWC, Fyrlyts.
    Nothing will stop damage where a Rottweiler is involved..
    Adelaide SA
    This is true.
    He is rehabilitated now. Hasn't chewed one since. ... the last one
    Sent from my GT-I9505 using AULRO mobile app
    May 2012
    there is always the old Clark Rubber cheap version - cut our 6 at a time and just replace the screws.... Mind you they Defender ones look nicer and the idea of a chain to hold them back when reversing (the cause of the demise of a few of mine!) is a good idea.
