27th May 2015, 03:58 PM
			Puma - current battery size
					Does the current Puma have a Din88 high (H 191 mm)  or a Din88 low (H 175 mm) battery?  Has there been a change from low to high since the introduction of the Puma in 2007?
                                                27th May 2015, 04:40 PM
					Doubt this pic helps.. Taken some time ago, battery in my 2013 puma, obviously local Malaysian content..
                                                27th May 2015, 06:30 PM
					Thanks Tact, but I was after details about the height (H).
                                                27th May 2015, 07:22 PM
                                                #4
					I've just measured the one I removed when I fitted my dual battery Optimas and it is 191mm high.
		You may not  post new threads
		You may not  post replies
		You may not  post attachments
		You may not  edit your posts
