Not so crazy actually...I'd have thought like you said, that you could swap over the top end...i.e. upper and lower intake manifolds, fuel rails and injectors, throttle valve/throttle position sensor etc. and associated hoses. Also the ignition coils. Probably also need to look at the cruise control cable etc. Don't know about the EMS... and whether you will need to re-sync the EMS with the BECM as part of the immobiliser system...
The Bosch set up has a different CKPS (crank posn. sensor) and also a different camshaft sensor.
The other alternative is to refurb the GEMS engine...the Bosch Motronic 5.2.1 EMS is virtually impenetrable in terms of engine remapping. I suspect you can tune the GEMS to get far better power and torque for a lot less money.
I am mightily interested in yr LS1 conversion. It's a great engine and even in standard form would be ideal. There were a couple of blokes some years ago in the UK who developed a bellhousing etc for the LS1 conversion but retained the GEMS sensors etc...so effectively, a Rover "system" running a GM long engine. They went broke but had the prototype running on LPG. They also used a different grind (less overlap at lower revs?) on the LS1 camshaft to improve low speed torque. IIRC the LS1 develops max torque at about 4000 rpm, but there's a lot of it between 1900 and 3000 rpm...
[/IMG]
