Not sure about the original part number, or even if they are available as a spare part... but I've gone down this path and have had limited success finding a supplier of large diameter grommets with the cable relief tail (well in the small quantities I need at least).
I acquired these but still not biog enough to fit a bulky wiring loom thru.
If you are relocating your factory fuse blocks into the ex box, then you can use the existing grommets. I used a squirt of silicone spray to help get it seated, as it's a tight fit. Your ex box kit should have come with an alloy sheet for blanking the holes in the D/S seat box.
