This is from Range Rovers Net
Rotor Arm Stuck: More than one RR owner has found the rotor arm stuck fast to the distributor shaft when trying to replace it during routine maintenance. Pulling up too hard on the rotor can break the plastic C-clip that holds the upper and lower parts of the distributor drive shaft together. Then you will have toi take the whole distributor out to put it back together. If it is stuck, break the old rotor off by hammering DOWN with a screwdriver or chisel and break it into pieces to get it off the shaft. Or use a center punch instread of a screwdriver.
Regard s Philip A
