Not sure what you are trying to achieve here. The reversing sensors turn off when you plug in to the std LR ( black ) trailer plug. The globe solution is to counter the vehicle not sensing LED trailer lighting. You will need to look up the latest posts on that issue. The later D4's don't seem to have as many problems dealing with LED lighting ( as they have LED's of their own ) You can always add an LED resistor into one trailer lighting circuit easier than wiring in a globe, if it is required.
  Reply With Quote D4  2.7litre
D4  2.7litre
