Thread: Carb issues
    Cessnock NSW
    Carb issues
    Can anyone tell me which is the slow running/idle jet in this diagram
    cheers Dennis
    Jul 2009
    S.E.Qld
    I believe that when the engine is idling the Pilot Jet #51 is in use. .W.
    not quite as simple as that on the solex as theres three adjustments theres one for the air mix theres one for the fuel and then theres the tapered idle screw t the bottom, unfortunately theres seemingly about 9000000000000 different carbie pictures out there that show them and I havent been able to find one tht lines up exactly with that parts diagram.
    whats the problem with your carby?
    Jul 2009
    S.E.Qld
    I find this book invaluable when working on a Solex.
    Cessnock NSW
    Well, this morning I made good on my word to strip the carburetor off the engine, I took it down to it's basic bits
    and yes then it started to sprinkle rain as you would expect, anyway I pressed on using the carby cleaner in a pressure pack
    then blew it all out with compressed air, re-assembled it and refitted it back on the vehicle
    primed the system hand and added a splash down the throat and it came to life, it is idling a tad fast with the choke out
    [ame="https://www.youtube.com/watch?v=1a5D-A-h_nQ&feature=youtu.be"]https://www.youtube.com/watch?v=1a5D-A-h_nQ&feature=youtu.be[/ame]
    but after it warmed it and the choke in, it does idle, yippee, now just need to be able to get it out and take it for a drive cheers Dennis
    ps It would not idle unless the choke was on approx. 1/3rd, which in turn made it lumpy @ idle and make plenty of sooty smoke, it now appears to be fixed LOL but anything could happen, anyway thank you for your responses, cheers,,.
