Thread: Towing a 1982 jayco swan with a 1995 discovery
    lanise Guest
    Hi everyone. We are about to go on a trip to Darwin then across to Cairns. No off road this time. However we are towing a big load, a 1982 jayco swan camper trailer. It is in good condition. I was just wondering if anyone has towed a swan with a 1995 tdi discovery. We realise we will not be fast! However as long as we can track along ok that will be fine.
    Has anyone done this and how did you go?
    By the way we changed the timing belt and thanks to all those who gave us advice. My husband said the info was great and he had no problems.
    Regards Lanise
    May 2002
    Sydney, Australia
    maybe get in contact with these guys http://www.thermoguard.com.au/ for 2 reasons:
    1. You may want to install the EGT (Exhaust Gas Temperature) gauge to monitor your exhaust temps while towing.
    2. They also use a Disco TDI for towing on long distances around Australia inc QLD
    they are also forum member - Leo109 is his log on
    But can confirm the Disco TDI is a good tow vehcile - not the fastest, but a good economical tow vehicle.
    HTH
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    Brisbane Australia
    I tow a 2000 swan with my v8 5 speed and Dad tows a 5.2 metre Coromal seka pop top (single axle) with his 97 TDI 5speed. The Coromal is taller and heavier than a swan. They will tow this sort of weight with no problem a Swan even over loaded will be no more than 1300kg, I asume you have electric brakes on the swan and controller fitted to the car. You will find that the car will cruise at 100-110km all day on the flat with no problem. I have towed mine behind the v8 at up to 130km. If the car is a 5 speed this is what you need to protect. Fill it with synthetic oil like Castrol syntrans and don't load or lug it in 5th. Do all full throttle overtaking in 4th and drop it back to 4th on any hill that starts to load the engine. We recently did 2k km From Brisbane south to Dubbo to take the kids to the zoo and then across to the coast both cars went fine, the TDI averaged no more than 13L/100km and there was a bit of hill climbing in this trip often down to 3rd gear several times a day. If the car is good you will have no problems and an enjoyable trip, best of all you can tell the Toyota Prado drivers around the camp fire you are useing 13L/100 not 25 like they are, even my V8 only used a max of 18L/100 on the trip which was less than all the Toyota drivers we had a beer with. Do you have a set of level ride bars? these make a lot of differance to the car, I don't mean a $500 Hayman reece load distribution hitch just a set of $145 level ride bars are fine. I would also recomend sticking a set of Kings springs in the rear about $140 a pair and 1 hour to fit makes alot of differance to the ride and pitching due to the extra wieght.
    Jul 2003
    Related to Shaunp's mention of rear springs you could also consider the installation of inflatable Polyair bags to level the Disco.
    Mahn England
    Ex 300Tdi Disco:
    lanise Guest
    Thanks for your very helpful advice. We really appreciate it. I will follow up with some of those suggestions. The exhaust temp guage sounds good so do the level ride bars. We have some sort of air bag suspension in the back already so this may also help.
    Sounds as though the car is made for the trip!
    Thanks Lanise
