Results 1 to 3 of 3
Thread: GME TX 3540 problem
    Huntly via Bendigo
    GME TX 3540 problem
    If I restart my Puma with the radio switched on it automaticaly goes into quite mode and I then need to switch it off and on again to get the thing out of the quiet mode. It happens on all channels.I have read the book but makes no mention of the issue. It appears to be the voltage drop that initiates it. A real P.I.T.A. Can anyone shed any light on it it is wired to the aux battery therefor should be isolated from any voltage drop caused by the starting drain.
    Lindsay.
    Where is it earthed?
    Something's not right! Can you post pics of the wiring install?
    Huntly via Bendigo
    Thanks, Tombie, forgot the earth will check when I get a chance today.
    Lindsay
