On a D3 you'll need more than just resistors. Look up "pulse shunt box"
Gordon
 Fossicker
						Fossicker
						This is my first request for information
I have recently bought a D3 and understand the problem with towing a trailer with LED lights on it.
The question is, Do i need to put resistors on the indicators ONLY or on all tail light circuits??
Gordon
 Fossicker
						Fossicker
						Thanks for the prompt reply
Not wishing to pay,( i believe $300.00,) do you know what is in the shunt box? as it will no doubt be much cheaper, and more interesting for me to make one.
This is after all only on a box trailer.
Go to a Ford dealer spare parts counter. They were selling one for the Ford Territory for something like $29.
 Wizard
						Wizard
						There are resistors to simulate the 21 w indicator bulbs and relays to prevent the pulses from activating the led indicator lights.
Fuji white RRS L494 AB Gone
2023 Ford Ranga
 Fossicker
						Fossicker
						 Fossicker
						Fossicker
						As Gordon points out,there is more than the resistor needed for the D3.D4 needs just 1 resistor.
I dont think the ford plug works,recall reading that here.
I bought a secondhand pulse buster,used it for the first time last weekend,re-wired the garden trailer with new wires and LEDs.With the indicators working it clicks,just like the dash so I think all it basically contains is an indicator flash can to activate the LED indicators at the correct speed,should you wish to look it up.
I could be wrong about the D3 info,I bet Gordon isnt.
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
 Fossicker
						Fossicker
						There's a sticky thread in this forum that contains great detail about this common (but easily solved) problem.
Have a read through and it may help you decide whether to build or buy a unit. I decided to build, it cost about $80 and took 4-5 hours.
http://www.aulro.com/afvb/d3-d4-rrs/...er-lights.html
Best of luck.
