Rich moved his AC lines when fitting oversize mud tyres. Some pics here:
http://www.aulro.com/afvb/d3-d4-rrs/...ml#post2220005
Has anyone moved their rear AC lines to fit larger tyres?
just asking first to find out if it's a difficult job or not before deciding on tyre size
I'd like the new BFG KO2 in LT265/65r18 but they're not available until atleast august but the date keeps slipping, so am thinking of the Nitto Terra Grappler in 280/60r18 which may have an issue with the AC lines? the Nittos are LT rated though
thanks
james
MY11 SDV6 HSE, e-diff, LLAMS, Snorkel, Rhino Pioneer Rack, DBS, BFG KO2 265/65r18, Mitch Hitch, GME TX3550s, GOE stuff....
 Master
						Subscriber
						Master
						SubscriberSome info here also
LR3/4 Rear AC Line relocation - Page 2 - Expedition Portal
Shane
Or,if you can,wait for the LT KO2 265/60/18 and then you won't have to move anything.
280/60 R18's you can get away without moving the AC lines, I did for years with 285/60 R18's which are approx 3mm larger in radius.
As long as you use Rods or LLAMS offroad all you will have is some minor rubbing on the wheel arch liner in particular on that seam rather than those lines. Yes it will eventually wear a line through it but thats no big issue.
The 275/65 R18 I am running is approx 19mm larger in radius than the 280/60's you are considering so it was a must for them to fit.
For you I wouldn't bother altering the lines and seam.
2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
True, but biggers always better right 😉
QUOTE=scarry;2379583]Or,if you can,wait for the LT KO2 265/60/18 and then you won't have to move anything.[/QUOTE]
Mate, it's a whole whopping 1.1"
And yeah an inch matters
True,but whats 1/2" between friends?..
Then again,you have more sidewall to play with as well.[/QUOTE]
