Results 1 to 3 of 3
Thread: 12 pin flat caravan connector
    Apr 2013
    Gympie
    Hi all
    could you please advise if i have got the wiring correct. the attachment shows what wires i propose to use to wire up 12 pin socket.
    Andrew
    Attached Files Attached Files
    May 2003
    On The Road
    From memory the smaller 6 are wired up as standard,,
    you can buy 12pin to 6pin adaptors.
    you can of course wire it up anyway you like,,
    just the car wont like towing anything else,,
    May 2013
    Howdy Andrew,
    Attached is the table I used to rewire the 12N/S to a 12 pin flat. Purchased a Narva 82072 12 pin flat quickfit trailer socket from Fleabay. Do want to redo the right-angle bracket I fashioned from steel to stainless. Still yet to put in the TowPro.
    Gordon
