Results 1 to 10 of 14
Thread: Confusion over using the supplied jack
    Aug 2013
    ACT
    Hi,
    I know this has been done to death a bit and that the supplied jack is crap according to many people but I am about to use the thing, picked up a nail causing a slow leak.
    I nave a MY14 D4 - 5 seat
    I have a few questions which I hope people can help with.
    1. I have read many threads here and else where which state to raise to offload height and leave the door open.
    I have read the manual and it does state to raise to offroad height but nothing about leaving the door open (ref p228 of handbook ). It does say to turn on the hazard lights, not sure if that helps or is just a motherhood.
    2. I have read about people using bottle jacks under the strut arm. Where abouts on the strut do you put the jack - I am a mechanical dunce so please forgive. Does any one have pics of this?
    3.I have read that some people trick the car by putting the jack under the strut, jack it up about 25mm, wait a second or two, release a little pressure to drop 10mm and magic happens, the wheel lifts off the ground. Has any one done this and if so do you have the doors open or closed?
    4. Some people use trolly jacks. Do you still use the same jacking point as when using the sissor jack. There are no other positions documented in the handbook for any other type of lifting.
    I do have a 2 tonne bottle jack I cart around in my van, this would not be enough I suppose
    Thanks for any help,
    Richard
    Ean Austral Guest
    I seem to recall you leave the door open so the car doesn't start trying to level itself whilst you jack it up.
    I have used the standard jack heaps of times, and it has been fine in a garage environment, and am sure yours will be. When you remove the wheel, put it under the chassis incase the jack does fail it will stop the car falling to far. Don't work under the car and you should be fine. You insert the nipple on the top of the jack into the hole on the chassis rail near the wheel you are changing as per the instruction manual, just be careful where the suspension compressor is as its close to the spot on the rear drivers side,
    I think the complaints about the standard jack are more related to off road situations where I can see it would be rubbish.
    I bent the tyre brace thing they supply as standard so carry a socket and bar with me all the time for wheel changing.
    Hope this helps.
    Cheers Ean
    Aug 2013
    ACT
    Ean,
    Thanks for the reply.
    The consensus seems to leave the door open, I would have thought LR would have included this is the handbook.
    I will be at home so doing it in a controlled environment.
    I am going to put a plug in the tyre and do not want to let the spare down.
    I have some jack stands which I will put under the chassis.
    Richard
    Yass NSW
    The other thing to remember is to use the supplied wheel chocks or the car will roll off the jack particularly if you are jacking the rear.
    Regards,
    Tote
    LRD414's Avatar
    Oct 2014
    Richard,
    Door open is not in the manual because it's not required for jacking from the chassis jacking points. You can jack from the chassis using scissor, bottle or trolley, particularly in a workshop/driveway situation. There's lots of threads on different bottle jacks and problems with using the scissor offroad. I've used the factory scissor and a bottle jack at home without issue.
    As an alternative, jacking from the wishbone is quite common and also does not require an open door or a particular type of jack. It requires a lot less jacking because the suspension does some of the work. There's probably plenty of threads here but I quite like this Disco3 one, especially the photos in CUCO's gallery.
    DISCO3.CO.UK - View topic - A better way to jack it up?
    An open door doesn't stop self leveling but rather prevents a selected height change, say from Normal to Access. This can be useful, I think Gordon covered it at the seminar in the context of hitching a van. Here's a great thread on that topic:
    http://www.aulro.com/afvb/d3-d4-rrs/...uspension.html
    To prevent any adjustments, the main suspension ecu fuse in the engine bay fuse box needs to be removed but that's not required for jacking.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Oct 2008
    Cloncurry NWQ
    I thought, could be wrong, you open a door to stop the car going into Super-Extended height?
    Most times I jack with the doors closed the car is in Super Extended when the jack is removed.
    It may? also stop the car pushing the wheel down as you jack.
    Jonesfam
    LRD414's Avatar
    Oct 2014
    Quote Originally Posted by jonesfam View Post
    Possibly. Super Extended is driver-activated after Extended is activated by the vehicle, either by actual grounding or simulated grounding with a jack or block of wood. The best summary of Super Extended I've seen is by Gordon (copied below & at link).
    http://www.aulro.com/afvb/1661658-post19.html
    If you need to raise the car to it's MAXIMUM height, without waiting for it to select extended height automatically, then follow this procedure with the car stationary, engine running, in low range and in Park:
    1. Place the car in whatever TR program required (normally rock-crawl).
    2. Raise the car to offroad if it has not already automatically raised (as it should when you select a TR program).
    3. Use the LR jack and position it under the driver's jack location under the chassis rail. Wind up the jack until it has just taken the weight of the car (you can do this by hand).
    4. Get into the car, close the driver's door and select "normal" height with the EAS switch. Don't apply the footbrake!
    5. The car will attempt to lower, sense the obstruction and then raise 35mm above offroad.
    6. Now apply the footbrake, and hold the EAS switch in the "up" position until the car chimes and raises a further 30mm or so.
    7. Remove the jack from under the car!
    Not sure why you'd want to interrupt that process but it may halt if you open the door during step 6. Also, you don't need these extended modes for jacking but I guess you could jack from extended.
    D3 2005 V8 Petrol
    Aug 2013
    ACT
    There does seem to be few variations on this topic 😅
    I was in LR today and asked and they said leave the door open.
    For me I don't care why, to bloody confusing, I am just happy knowing you do, although some people say you don't
    While at LR I asked about jacking under the suspension arm or what ever you call it and they knew about it but did not have the details
    Is there a video or pics of this as I am not sure where you place the Jack
    As it turns out I don't have to worry about it now, at least, LR are going to fix my tyre for free.
    I am finding the local LR guys ,Lennock in Canberra, very easy to deal with and very helpful .
    Richard
    1. Leaving the door open is supposed to stop the car from changing height. I have done this but I still would put any body part under the car.
    2. Why bother? There are jacking point on the car. All you need is the right jack.
    3. Never done this to change a tyre, nor would I. I have done this trick once or twice to get the car into extended mode (and keep a bit of timber under the back seat for this and to act as a jacking support) to get over obstacles off road.
    4. Ditto 2.
    2 ton bottle jack? It's not the tonnage...its the reach. You have to select a jack that'll raise the car high enough. I have a 3 stage jack that fits under the rear seats that does the trick.
    Quote Originally Posted by wbowner View Post
    Hi,
    Richard
    Aug 2013
    ACT
    4. Ditto 2.
    The right jack?
    According to LR that is the scissor jack.😀
    The reason for my other options I mentioned is that a lot of people keep stating the one provided is crap. I am just looking at other options.
    A bottle jack would also be a bit unstable by itself I reckon.
    Richard
