Thread: transmission ratios
    Apr 2012
    jimboomba
    transmission ratios
    can any one tell me what automatic transmission is in the range rovers ( around 1999- 2000 models) 4hp22 or 4hp24 & what the gear ratios are ?
    Aug 2014
    Echuca
    Quote Originally Posted by garney View Post
    I replaced one of these a year or so ago, from memory I believe the 4hp22 is used in the 4.0 and cant or shouldn't be used in the 4.6, as they aren't strong enough. But the 4hp24 can be used in both the 4.6 & the 4.0.. Someone with a little more knowledge here will be able to explain more but I fitted a 4hp24 (replacing a 22) to my1998 4.0 and is all good, no idea on ratios sorry
    May 2010
    Mindarie, Western Australia
    garney
    AUTOMATIC TRANSMISSION
    Automatic gearbox
    Model
    2.5 litre Diesel & 4.0 litre Petrol ............................... ZF4HP22
    4.6 litre Petrol .................................................. ........ ZF4HP24
    Type .................................................. ............................... Four speed and reverse epicyclic gears with fluid
    torque converter and lock up.
    Transfer gearbox
    Borg Warner .................................................. ................... Two speed reduction on main gearbox output, front
    and rear drive permanently engaged via a centre
    differential controlled by a Viscous unit giving a 50/50
    nominal front and rear torque split.
    Transfer gearbox ratios
    High .................................................. ................................ 1.216:1
    Low .................................................. ................................ 3.271:1
    Automatic gearbox ratios
    4th .................................................. ......................... 0.728:1
    3rd .................................................. ......................... 1.000:1
    2nd .................................................. ........................ 1.480:1
    1st .................................................. ......................... 2.480:1
    Reverse .................................................. ................. 2.086:1
    Overall ratio (final drive): High transfer Low transfer
    4th .................................................. ......................... 3.13:1 8.43:1
    3rd .................................................. ......................... 4.30:1 11.58:1
    2nd .................................................. ........................ 6.37:1 17.14:1
    1st .................................................. ......................... 10.67:1 28.72:1
    Reverse .................................................. ................. 8.98:1 24.15:1
    Gary
    2007 Range Rover Sport TDV8
    Modified 1996 p38a HSE sold
    Apr 2012
    jimboomba
    thanks for the info.i intend to install a v8 gear box in my td5. the v8 box has a extra fiber plate in the A clutch pack -a stronger c' - c' freewheel clutch & stronger planertry gear sets. the valve body is also the same. i tow a 2.9 ton caravan.i would also like to install the v8 torque converter as well.it has a stall speed of 2400 as to the td5 of 2800. i think the T. C . lock up clutch i s bigger as well. just need to make up a modded drive plate.
    Garney
    May 2003
    On The Road
    I would stop asking question here now and re-ask in the D2 Forum,,
    There are LOTS of things you need to know before a swap.
