Thread: Carburetor rebuild for 112-655
    Cessnock NSW
    I dropped this item off last week and picked it up yesterday after work
    today sometime I will remove the carburetor from 112-655 and make a start on it, cheers Dennis
    Cessnock NSW
    From yesterday, I removed the carburetor which is a simple enough job, once you have the bonnet up out of the way
    here are the tools required to remove the carburetor (if it hasn't been modified by a prev/owner)
    then to dismantle it a good blade screwdriver is needed and if your like me the good book close by to refer to as required, I didn't change too many things inside the carburetor as the numbers on the parts did not match what I was going to remove, so all put aside until I can talk to either Murray R (Modern mtrs) or some-one just as knowledgeable, a mad scramble late in the afternoon (storm front dumped 8mm rain) so it was re-assembled in the shed and re-fitted this morning.
    Here is a short clip of the engine running before I adjusted the idle screw
    [ame]https://www.youtube.com/watch?v=fHbR5SOZ0yM[/ame]
    back, and with it raining late yesterday, I don't want to move it across the grass as it will sink into the ground and possibly upset swmbo LOL, anyway when I do move it to road test it I will also road test 172-562 workshop truck, cheers Dennis
    I find that the best way of holding the bonnet upright is an okkie strap from the edge of the bonnet to the back of the door frame.
    Cessnock NSW
    Yes John, I have to agree with you or remove it altogether, but the gunbuggy doesn't have anything to secure a ockey strap too LOL, and it's too much trouble to remove the cam net attached to the bonnet and the bonnet is a 2 person job (for me now a days) cheers mate Dennis
    Quote Originally Posted by Dinty View Post
    A bit of rope to the back of the vehicle?
