28th June 2015, 12:39 PM
Removing Fan
Gday All,
Anyone know a trick to remove the fan without the special tools. ?
I know its left hand thread but haven't been able to keep it from turning
Cheers Ean
28th June 2015, 12:45 PM
its ok I got it, just had to think about it abit longer.
Cheers Ean
28th June 2015, 12:54 PM
So tell us the results of your thinking?
28th June 2015, 01:08 PM
#4
There s 3 small bolts in the pulley that the fan screws onto, rotate till 1 is at about 7 oclock , 10mm spanner on the head, shaft of the spanner runs against the hub nut ( so spanner is facing 9 oclock to 3 oclock ) hub spanner on top, quick hit on the spanner and it came loose.
Cheers Ean
