Results 1 to 10 of 20
Thread: Ignition cuts out when brake pedal pressed
    May 2010
    I have searched the archives and can't find a precedent for this problem, so thought I'd ask if we have an exorcist here...or even a few ideas? My p38 had been sitting unused for a few months with the battery disconnected (brand new), but it started ok. After driving it a few miles it developed the usual ghost in the machine symptoms of radio turning itself on and refusing to turn off, gearbox fault, and eventually the instruments and ignition cut out whenever I used any electrical item such as blinker, brake pedal cabin light, headlights etc.
    Alright, I know that the P38 loves voltage, and lots of it, so I put the battery on a charger overnight. Next day I could start her up but pressing the brake pedal caused the ignition and instruments to cut out. Other electrical items had no ill effect. By removing the brake switch fuse, I was able to restore normal function and drive home (a little cautiously with my eye on the rear view mirror) without brake lights.
    Any ideas guys?
    Feb 2010
    Townsville, QLD
    I'd say that your alternator is kaput.
    It doesn't explain the problem, but I think it'll go a long way towards fixing it.
    Keithy
    May 2010
    Mindarie, Western Australia
    A quick test to see if your voltage is the problem. Try turning on the headlights. If it stops or hiccups I'd be looking potentially at another battery. Then of course there are the multiple earth connections. Definitely worth a check up.
    Gary
    2007 Range Rover Sport TDV8
    Modified 1996 p38a HSE sold
    May 2010
    Thanks Keith and Gary. The alternator was putting in 13.3 volts when I checked and the ghost in the machine symptoms disappeared after I fully charged the battery. All that remained was the ignition and instruments going dead only when the brake was pressed. No other electrical items including headlights caused a problem, only the brakes. If there was a dead short in the brake light circuit, I would've thought the fuse would blow but perhaps it's only shorting enough to trip a relay? Or maybe there is a ghost inside the BeCM.
    But I know one thing...brakes are suppose to stop the car _ not the engine!
    Feb 2013
    Gosford, NSW, Australia
    Hi
    I would suspect an earth connection, the one behind the side panel where the bonnet release is.
    Also worth checking the under bonnet ones
    Steve
    Mar 2009
    Bexley NSW 2207
    if you are around the area of Bexley or up to Padstow, i can have a quick free look at it (rover electrics is what i do for a living) ring me 0421509083 regards Rupert
    May 2009
    Tatura, Vic
    Quote Originally Posted by Rupert Prior View Post
    You must be a very busy person
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Mar 2009
    Bexley NSW 2207
    not so much now, values are low, parts are expensive, even some sports are beyond economic repair.
    May 2013
    Launceston
    Now that you've fully charged the battery, start the car, turn the rear window heater on, high beam headlights on and heater fan in max. Hold the engine at 2000rpm. What voltage are you getting across the battery then?
    Is it ok to post a link to a post I wrote on another Range Rover site about how to diagnose this?
    Oct 2010
    Carindale, Brisbane, Qld
    Quote Originally Posted by Ghind View Post
    Your electrical sticky has helped so many over the years, I certainly hope it is ok to link to from here...
    Now: 2005 L322 Vogue 4.4 M62TU (Black)
    Before: 2000 P38A HSE 4.6 - stately capability | 2008 Kluger KX-S | 2004 Forester | 2000 Yamaha XJR1300 | 1993 VR Calais | 1974 HQ Statesman - 308 V8 | HT | HK
