As far as I know only GOE Compomotive 18" rims fit. Have a look at the distance between the inside of a front rim and the calliper. That will give you an indication. There's very little room on my tdv8 RRV with 19" rims.
Hi guys,
Just a quick question can I fit 18 inch rims on my 320 TDV8 or are the brakes to big.
TIA
Dan
L322 tdv8 poverty pack - wow
Track Trailer ARN 200-117
REMLR # 137
Dan.
As mentioned Gordons Green Oval wheels are the only 18" to fit the larger braked RRS and D4 models.
Check his Green Oval Experience website,pretty sure they dont fit a supercharged V8 RRS but fit everything else.He is the only place to get the compomotive rims at the moment.
There is a mod where you grind the front calipers in a certain spot to fit aftermarket rims.Not good practice I would think.
A workmate is off to Exmouth on friday for a couple of weeks,lucky barstard!!!
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
I was about to ask this exact question but for the non brembo TDV6 model.. can I fit 18s on that?
It has 20s atm, and that doesnt seem at all ideal for offroading...
REMLR # 137
REMLR # 137
