Well seeing that all early 3.5 Discos did not have sway bars I do not think the world will end if you take them off.
However it will body roll a lot as the front springs are 133Lb per inch and the rears dual rate 150/220 lb.
I would change the springs for 160LB per inch front and straight 220 rears.
I have done 160LB front and 180 lb rears on my 92 Range Rover and this is almost exactly the Rover HD spec without roll bars. I am VERY happy with mine, but you may not like it. To me its a LOT better off road and on secondary country roads. Roundabouts are the only downer.
I think it would be hard for an insurance company to claim non roadworthy seeing there are hundreds of thousands of non roll bar cars on the road. I THINK that the Disco commercial in UK never had roll bars, so you can argue that the factory made em like that up to the end.
In 92 There was a Hunter Range Rover in the USA without roll bars so I believe I am OK but I do noit think it would ever be an issue.
Regards Philip A
