Thread: APT Salisbury Diff Guard
    May 2011
    Brisbane Queensland
    Hi Folks
    We have fabricated a limited run of Salisbury diff guards. They are made from:
    • Mounting ring is 8mm 350 grade steel mounting ring, flat milled
    • 'Hat' is 6mm laser cut and cnc folded 350 grade steel
    • Great departure angles due to steep exterior design
    • Button head M10 12.9 high tensile rated bolts ? 10 bolts that use the factory holes
    • Filler plug in the correct factory location to ensure you get correct fluid levels
    • Straight bolt on accessory no welding needed
    • Zinc primed and powder coated red
    • Straight forward install
    PM for more information or visit the website APT Fabrication Custom Land Rover Parts & Accessories - Land Rover APT Salisbury Diff Guard | Defender
    Ben
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Will this fit the Sals rear end on a Series 3 - 1977?
    Apr 2014
    Blair Athol, Adelaide South Aust.
    Quote Originally Posted by bacicat View Post
    X2 cheers Rod
    Ps discount for multiple purchases say 2 off???. I know, im a cheeky sod :thumbup:
    Sent from my GT-I9507 using AULRO mobile app
    May 2011
    Brisbane Queensland
    sure will cheers Ben
    May 2011
    Brisbane Queensland
    Quote Originally Posted by 67hardtop View Post
    X2 cheers Rod
    hi rod sure we will look after you. Pls call (07 3162 0690 bh) or email (sales@aptfabrication.com.au) and we can discuss. cheers Ben
