Results 1 to 10 of 11
Thread: Silly question time!
    Jan 2014
    Melton, VIC
    Ok, so it's probably a simple answer but how do I go about getting oil into the gearbox?
    Additional to this question, I am trying to see what sort of state aforementioned gearbox is in without having to take it out/apart, is there any way of doing this or am I going to have to suck it up and dismantle the whole car
    In general I have not noticed any issue with the gearbox itself, but if there is some way to check it out I feel it would be worth doing.
    ~Dan
    Aug 2012
    Adelaide
    I normally use a funnel and a piece of hose to fill the gearbox and trans. Put it up through the middle seat hatch.
    Condition checking.... don't know.... I'm just going to suck it and see.
    99.87 MB
    Im guessing you can't test drive it?
    Slunnie
    Jan 2014
    Melton, VIC
    Sadly no I can't test drive, don't have anywhere large enough to get out of first gear lol. Need to find someone with a field, and trailer
    Jan 2014
    Melton, VIC
    Ok so I have found a couple of what look like inspection covers and a filler plug under the middle seat, once the oil has worked into the bolts I guess I shall have a gander in there and see what gives, usual oil or something special?
    Early Series gearboxes have a filler and dipstick on top, accessed through a swivelling plate on top of the transmission tunnel. But by Series 2 time the only filler is the level plug on the side. Usual method is a pump and hgose - I use a 20l drum with pump.
    Gearbox, transfer case, and diffs, swivels, steering box, steering relay use EP90 or 85, preferably GL4 not GL5.
    Jan 2014
    Melton, VIC
    next silly question, how much oil does it take, or how far should I fill it, I removed a cover which was underneath the middle seat area and there is about 2mm of oil at the bottom of it, looks generally clean in there. Though I suspect I am not actually looking in the gearbox, had a picture but my phone decided to fall in and isn't working at the moment.
    Fill to level plug in the side, approximately 1.5l.
    May 2015
    Southern Adelaide
    In general, that's pretty typical for this sort of thing - gearboxes, diffs, etc. If it has a plug in the side, fill till it starts to spill out. It's better if you can check the manual of course, but this is a good rule of thumb.
    And yes, all the British manufacturers had a mania for making filling these things an exercise for double jointed spider monkeys who didn't mind getting fluid all over them. Feel free to swear, everyone else does.
    if you haven't run it and are worried about what might be in it, drain the oil into a container and look at the speckles of metal in the drained oil,
    if there are lots, allow it to settle and drag a magnet through it, there shouldn't be too much for a gearbox that is regularly serviced.
    but as you cant run it too much, I would also flush the box with a cheap fluid, petrol, turps, diesel, jet a1, several times until the drain comes clear and refill the gearbox with your choice of oils, I would use a cheaper one and run the box for a while and redo the oil change.
    once you get it on the road and able to drive it for a while, I would do another oil change, of all oils to see what the condition is.
    Safe Travels
    harry
