Results 1 to 6 of 6
Thread: Off-centre steering wheel
    Ty Guest
    How do i adjust the steering wheel so that it is straight?
    Just had the steering box replaced, and after i showed the mechanic how to adjust the play i sort of lost all confidence in his abilities, so i'd rather finish the job myself.
    ty
    SAFETY BEACH Victoria
    Ty
    First make sure the wheels are straight.
    then pull the steering wheel of (the nut is the same size as your wheel nuts SW 27mm and a basic bearing puller will do the job)
    then put it back on the way you want replace the nut just so you don't pull the wheel of the spine wile driving up the road to see if it is straight. If OK do the nut up and your done
    10 min top's for the job [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img] [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    Kai
    May 2002
    Heathcote (in "The Shire")
    Better option,
    Lock the steering box with a 1/4 drill and get the steering wheel central by adjusting it at the steering shaft splines. Take it for a short drive (dont forget to remove the drill [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] ) the bring the steering wheel back to centre by adjusting the draglink (not the tie-rod). This will make sure the box is right relative to the self centreing ability (apparently very few are correct from the factory) You may have to adjust a couple of times to get it spot on.
    Steering place explained it to me when I replaced my box, steering feels good and self centres very well, whats more its easier to do than explain.
    Bushie
    SYDNEY -in the shire.....
    you should also check that the steering box is centralised first before you adjust the draglink..........otherwise you may have one and a half turns to one lock and three to the opposite lock.....
    from memory there are three and a quarter or three and a half turns from lock to lock.....
    it is a very quick and easy job to do.....a 10mm spanner and a set of multigrips......
    NSW far north coast
    POWER STEERING BOX - ADJUST
    Service repair no - 57.35.01
    WARNING: Adjustments of steering box
    should not be required while in warranty
    period. If box is stiff or tight and within
    warranty, it must be returned to manufacturer. No
    attempt must be made to introduce backlash.
    1. Apply park brake brake, chock wheels and Jack
    up front of vehicle until wheels are clear of
    ground.
    2. Support chassis front on axle stands.
    3. Disconnect drag link from steering drop arm.
    4. Check torque to turn See Fault diagnosis,
    Stiff Steering Checklist.
    5. Centralise steering box See Centralise
    Steering Box.
    NOTE: Only check for no backlash when
    steering box is in central position.
    NOTE: If steering wheel is not straight, it
    should be repositioned See Repair,
    Steering Wheel.
    6. Adjustment is obtained by rocking the drop arm
    about centre whilst an assistant slowly tightens
    the steering box adjuster screw.
    7. Tighten locknut when all backlash has been
    removed.
    8. Repeat the check for backlash. If backlash exists
    loosen locknut and repeat adjustment
    procedure.
    9. Turn steering wheel lock to lock and check no
    tightness exists.
    10. Ensure front wheels are aligned and in straight
    ahead position.
    11. Adjust drag link 924 mm between ball joint
    centres.
    12. Connect drag link and tighten to 40 Nm (30
    lbf/ft).
    13. Lower vehicle to ground level and remove
    chocks.
    14. Road test vehicle See Fault diagnosis, Road
    Test Procedure.
    Drag link adjust
    1. RH drive vehicles - if steering wheel is to right,
    drag link is too long. If steering wheel is to left
    drag link is too short.
    LH drive vehicles - if steering wheel is to right,
    drag link is too short. If steering wheel is to left
    2. Adjust drag link until steering wheel points
    straight ahead when vehicle is travelling in a
    straight line.
    CENTRALISE STEERING BOX
    Service repair no - 57.35.05
    LH drive vehicle
    1. Disconnect drag link from drop arm See Repair,
    Drag link and drag link ends.
    2. Turn steering wheel on full RH lock.
    3. Turn steering wheel back exactly two turns.
    4. Fit drag link See Repair, Drag link and drag
    link ends.
    RH drive vehicle
    1. Repeat operation for LH drive vehicle but turn
    steering wheel on full LH lock.
    Ty
    Here's an even simpler solution. Take it to someone to have the alignment checked. While they're at it they can do that at the same time.
    As long as the box is centered it's a simple job when they adjust the toe-in.
