Funny, was just talking the other day to a guy in Wyndham caravan park with exactly the same issue as you describe
 Member
						Supporter
						Member
						Supporter 2013 D4 Front Diff and drive shaft replacement
		at beginning of our 4 month trip, travelled from Melb to Adelaide , 2.5 ton van. On arrival we had a clunking noise when taking foot off brake or shifting gears. Solitaire Adelaide inspected and found knocking sound from driveline, driveline movement, leak from drive shaft and excessive play from front diff. Removed and replaced front diff and drive shaft. (46000klms) all under warranty. Good service. 6000 Klms later with some rough roads- all ok. Anyone had similar issues.
2024 RRS on the road
2011 D4 3.0 in the drive way
1999 D2 V8, in heaven
1984 RRC, in hell
 Master
						Subscriber
						Master
						SubscriberFor my ex Prado (150) it had a service at 24k, they gave it I think a 48k service (the mileage was low for its 2012/3 age). Toyota changed all the differential lubrication.
i spoke to an authorised Mercedes repairer, and told him about buying a Discovery (Rolf Graunke in Ferntree Gully). I told him I would be changing the motor earl earlier and also the gearbox due to LR not specifying when. He said the Disco was pretty good re reliability, but that I should change the differential oils too.
 Member
						Supporter
						Member
						Supporterthanks Ferret. That was me!!!! Cheers
Don't hear of that very often..
These things happen and it was all fixed.. Push it to the back of your mind
 Master
						Subscriber
						Master
						SubscriberIf it was out of warranty, you could have put in a locking front diff. ARB still supply those to today's D4s. None available for the rear diff anymore ... shame as I don't have the e-diff.
Do they write D4s off, or repair them? Can one fit an e-diff (rear diff) from another wrecked Disco?? Or even buy one from a parts supplier and have it fitted?
 Master
						Supporter
						Master
						Supporter Master
						Subscriber
						Master
						Subscriber| Search AULRO.com ONLY! | Search All the Web! |
