I'm guessing that if you put too much in there, that it expands when hot and blows out the seals. :-\
Gday All,
I have been wondering why the front diff recommended fill level is 0.61ltr so decided today that I would see how much oil it would take if I was filling it the old conventional way of letting it come out the fill point.
0.70ltr was what it took , there cant be much room inside that diff housing.
Waste of time I know but what the hell I had to satisfy the curiosity.
Cheers Ean
So why didn't they just put the fill plug a bit lower,then it becomes the level plug as well?
I bet there are a few around with .7l in them.
Maybe for the first (dry) fill at the factory when built? Who knows, they obviously have their reasons - however twisted they are!
Ean, just before I left on this trip I changed both front and rear diff oils and they were both filled to the level plug, I know the the last time they were changed was a one of the Perth dealers so even they over fill them.
regards Roger
When I done my front diff I put in the measured amount and it turned out to be just on the fill plug, just started dribbling out as I got around the .6L mark. But then again my "measured" amount might not have been all that acurate
Shane
2005 D3 TDV6 loaded to the brim with 4 kids!
http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
This make no sense at all considering LR has been fitting diff breathers since 4 ever.
My guess is just to maybe be more 'eco' as not encouraging people pour oil on the ground to get the fill. Or maybe to stop something going up the breather and coming out the other end and leaking on the ground.
I just did my front and rear diffs (MY10 RRS (same as D4)) and they both overflowed at the amount they are meant to take to fill, I mean think about it. There is a going to be variation in how much oil you get out depending on its temperature/viscoscity and how long you wait for it all to drain out if even possible to get it all out in a practical time.
Also I found the torque specs for the fill hole to not be correct.
The lower spec was 28NM and this is the 3/8" bigger plug, and easy to do, but the fill is spec as 34NM (smaller allen socket) and i had this screwed in deeper than i took it out and it felt no where near clicking off so i just stopped, and figured that has to be enough and ill just check it for leaks later.
Yep after measuring precisely a few times the exact quantity it is so close to the overflow point it could not make any possible difference to overflow in my mind.
 TopicToaster
						Subscriber
						TopicToaster
						SubscriberI just fill to overflow given there’s about 20ml in it.
2007 Audi RS4 (B7)
