Results 1 to 10 of 29
Thread: Rivnut Tool(Nutsert,etc)
    Williams West Aust
    Ive just been reading the latest Kincrome cattledog,they have a Rivnut set thats M3 M4 M6 M8 M10 for $129.00,includes 60 nut inserts.
    My next campertrailer job is to build the solar panel setup.I did buy a combination of pop rivets and stainless bolts/nylocks for the job.
    Thinking now of using Rivnuts instead of pop rivets,thinking they are stronger.
    Now,do I order Stainless nut inserts or Aluminium????
    The stainless bolts I have are all 304.The frame will be 3mm and 4mm aluminium section.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Feb 2005
    I normally only use nutserts for spots you cannot get a second spanner too.......
    Nylocks rarely come loose......same with big arse rivets.
    There is a little trick after you have drilled the hole for a nutsert......grab a round file and file a little nick in the hole.....the reduced the chance the the nutsert spinning when you undo the bolt
    Brisbane,some of the time.
    Make sure the nutserts are the type with splines on them,then they never turn,as long as the hole is the correct size.
    We always use splined nutserts,often up to M12,and never have any issues.
    Williams West Aust
    Ive ordered a kit.
    Now I know the answer,would like confirmation.
    Using 304 stainless bolts,I should be buying 304 nutserts,fixing in aluminium.Avoiding electrolosis on the threads.
    Andrew
    Williams West Aust
    I assume they tell you what the drill size is for each nutsert size,correct???
    Andrew
    Andrew
    They should do,if not make sure you ask.Different brand nutserts use different size drill bits,even though the thread may be the same.
    Also different nutserts are designed for different thickness material,this is important as well.
    I use Aerobolt for our nutserts,there is some good info about nutserts on their site.
    Hope it all works out.
    May 2014
    Tamworth NSW
    I bought my nutsert gun off ebay. Nothing flash, but then again, i'm not using it in a hardcore production line environment. I think I've put 5 nutserts thru it in the past 10 months. I paid approx $80 and got a range of steel and aluminium nutserts to go with it.
    The mandrels with mine don't necessarily instill supreme confidence, but then again, I wouldn't swing off it more than I needed to.
    -Mitch
    'El Burro' 2012 Defender 90.
    Williams West Aust
    Thanks Mitch.
    I nearly bought an ebay special last year but decided no.When I saw them in the Kinchrome cattledog I was more than happy to buy.I have plenty of Kinchrome tools,all top quality stuff.
    Andrew
    Williams West Aust
    I finally got my kit today,been on back order all this time,none have been available in aust.
    Got it for the sale price advertised,$129 so very happy.Just ordered a few stainless nutsert kits.Will be able to make my solar panel setup for the camper trailer soon.
    https://www.kincrome.com.au/nut-rive...-handle-68-pce
    Andrew
    Aug 2008
    Perth, WA
    37.36 MB
    Hey Andrew,
    Looks like Bunnings now have this kit for $130. I might have to go in tomorrow and double check it is the same one.
    Kincrome 68 Piece Twin Handle Riveter Blindnut Kit I/N 5910346 | Bunnings Warehouse
