Thread: D3 2.7tdv6 2007 HDC issue
    Jul 2012
    Toogoom, QLD
    Gents
    Was driving to the bean counters this afternoon and vehicle running normally.
    Was stopped at a set of lights when bong bong centre screen on the dash states transmission fault and other things I could not see in time.
    Next HDC fault indicated and Christmas lights on the dash. Suspension lowered
    Pulled over and did the normal lock unlock 3 times to reset. Started up and faults cleared.
    Will see how it is once I drive home.
    Any thoughts??
    Peter
    LRD414's Avatar
    Oct 2014
    Peter, sounds like the initial symptoms of a faulty brake light switch.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Jul 2012
    Toogoom, QLD
    Thanks mate. You could well be correct. Unjust drove back from Ipswich to corjnda with no issues.
    Now you would think I'd get more than 201,000km out of the switch hehe
    Williams West Aust
    Quote Originally Posted by PeterOZ View Post
    If you never used your brakes it would be as good as new!!!!!
    At least its not an expensive fix if you DIY.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Jul 2012
    Toogoom, QLD
    yes I think I should be able to handle that one. I'll order one in from brit part of similar and pop in the glovebox that way the original will keep working forever!
