Results 1 to 3 of 3
Thread: slight water leak Disco 2
    Ringwood, Vic
    I have noticed a small water leak in the Disco11. Seems to be coming in the roofline windows in the gargo area. I reckon I can fix it with a silicon gun but can't figure out how to get the internal panels off so I can get a look.
    Help would be appreciated!
    Alan
    D4 SDV6, a blank canvas
    BigTed Guest
    Wardy,
    I had water coming into the rear of my Disco II, and found the entry to be the rubber gromet on the roof. I believe it's where the satalite nav system is mounted in Europe. Anyhow just thought it might be worth a mention, water can travel and seem to be coming from where it isn't.
    Sorry can't help with the removal of internal panels, but worth investigating other areas once you get them off.
    Ringwood, Vic
    thanks mate bt mine doesn't have doesn't have the sat nav grommet. Will have a good look around once i get the panels off
