Get an efi version, you will be much happier and the lpg conversion is straight forward for these as it is with single carb versions. My 84 is currently set up for lpg only using a gore research system, if for any reason I want to convert to dual fuel then it is just a matter of getting a 4 barrel carby, a lpg mixer ring and a petrol tank and plumbing. The system I have uses an Offenhauser 4 barrel inlet manifold which is a low profile version so gives good bonnet clearance with whatever you put on top.
