It was the LR OEM 18" that was talked about.It will fit a D4 3.0l rear axle only.
As for the 19" i am not 100% sure,but if it is LR, OEM,i recon you will be OK.
I am sure others will chime in
Does anybody know for sure if a D3 19" wheel fits on the front of a MY14 3.0lt D4??? Are the off-sets the same????
I do recal reading somewhere that they may only fit the rear axle,had a search,cant find the info.
Brian has split his set,considering one for a second spare to mount on the camper trailer.
http://www.aulro.com/afvb/wheels-tyr...els-tyres.html
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
If I dont get a definitive answer by thursday I will ask the dealer,booked in for the first service.
Andrew
I only have a D3 but I thought 19" would fit but not 18" on the front unless they are the customs like Gordon's etc.
The standard 18" fit the rears ok though.
2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
Hello LandyAndy,
I have the same wheel as a second space for my D4 MY11 SDV6 SE.
I have it mounted to the rear of the caravan.
I must admit that I have never actually fitted the wheel to one of the front wheels.
When I investigated and asked around about the size, I was told it would be all good. The wheels you are looking at are originally from a D3 HSE V8 (6 Spoke) which had the larger brake package.
Attached are a couple of photo's of the wheels I purchased with one of the photo's showing the details of the wheel from the rear.
I am currently away for work but I am happy to fit one to the front to be sure if you would like.
NTB
The other day in Bunnings carpark in Kalgoorlie, I saw a D4 SDV6 HSE with four of these rims fitted. I spoke with the owner of the vehicle, as I did not think you could fit D3 rims to a D4 with the 3 litre V6, but he told me that they were off a D3 and he had no trouble with them fitting front or rear.
He had just returned from a trip out bush, and said that he bought these so that he could run 18" A/T's when touring, and then change back to 19" H/T's on his original D4 19" rims when he was home.
Should have taken a photo, but didn't think of it at the time. I noticed it as soon as he pulled in to the carpark, as I had always been told that you couldn't run D3 18" rims on this model D4 -
Cheers .........
BMKAL
I didn't check the tyres myself, but the owner said that they were 18" (his original D4 rims are 19").
Definitely a 3 litre - was a HSE and had SDV6 badge on the tailgate.
Confused the hell out of me too. As I said, should have taken a couple of photos.
Was a local vehicle, so I'll keep my eye out for it around town. If I see it again, I'll take a couple of pics (and check the wheel diameter / tyre size myself).
Cheers .........
BMKAL
So we are saying the D3 V8 ran 18" rims that are LR OEM and fit the front of a D4 3.0L?.
Umm,interesting.
Doesn't help the OP,though,we have wandered off topic again…...
Interesting Brian.
These are 19" as per the advert.
Andrew
