Results 1 to 8 of 8
Thread: ABS, HDC, TC Lights. Faults cleared without Testbook/T4
    BruceArgyle Guest
    Hi group,
    Only new here so I am just wondering what the latest threads are on the infamous ABS, TC, HDC lights might be.
    I had read of a reset of the SLSABS ECU memory where the DTC's are stored. ie disconnect the battery and let the capacitor discharge in the ECU that is storeing the fault indicators. Thought I would give it a try but to no avail even after 12 hrs over night the lights were still on. Has anyone heard of this or had any sucess.
    Has anyone acquired testbook/T4 and a suitable interface?
    Bruce
    TD5 Man SLS 7 seat
    Tregeagle, NSW
    Bruce,
    I have had a fault in my ABS for ages(it won't work). I put a post on ages ago and didn't get any replies regarding what you suggest. I'l watch this closely, if there is an easy fix.
    But I have been told there are a number of things that can cause the ABS to go down, from sensors to wiring. ( the rest I can't comment about)
    As yet I haven't gotten around to climbing under neath to check everything i was told about.
    john
    SYDNEY -in the shire.....
    <span style="color:blue">there is a connector somewhere that you need to earth out one of the pins in.........but i cant give any info as i dont know where or which pin...</span>
    Redcliffe, QLD
    Hi Bruce,
    where do you live? If you're in Sydney, I may be able to help.
    MARCEL
    <span style="color:blue">do you have the book of how to do things without testbook?
    i would be interested in that......
    it can be done with a multimeter but you need to know which pins to earth out and which to check....in what order.....gotta have a book....</span>
    xlr8it Guest
    I would be very interested to know as well as I need to reset my SRS light on my Disco 1 and do not feel like paying $75+ for 2 minutes of labour.
    Redcliffe, QLD
    A multi meter is an extremly valuable tool, but I haven't heard of it being used to clear SLABS ECU (Self Leveling/Anti-lock Braking System) faults with.
    I have a Testbook/T4/WDS unit for this.
    Let me know if I can help.
    MARCEL
    BruceArgyle Guest
    Hi Marcel,
    I am in Melbourne, sounds interesting, please drop me a line off forum.
    bruce.argyle@ndcglobal.com
    Bruce
