Results 1 to 10 of 12
Thread: How far does a Tdi300 go?
    drooby Guest
    Hey all.
    We have owned our '97 Tdi for about a year now and in that time I have replaced:
    Lift Pump
    Injectors
    Reco'd Injector Pump
    Rear tailshaft Joint
    She runs well now and has 220,000 on the odo.
    Timing belt was done at 198k.
    What should I be keeping an eye on?
    What sort of life expectancy can I expect?
    Thanks in advance guys!
    I'd Rather Push My Land Rover in QLD Than Drive A Toyota in NSW
    The LR sevice life is 400,000 miles from my research, however this is highly dependent on service regime and driving styles.
    You will get plenty of replies that 300,000kms is pretty common with few problems occuring, at least I'm hoping so as it will give at least another 160,000 plus before anything major is required.
    Glen.
    May 2002
    Sydney, Australia
    Glen its actually 400,000 Miles!!! so about 640,000 kms
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    Originally posted by seqfisho
    The LR sevice life is [size=18]<span style="color:red">400,000 miles </span>from my research, however this is highly dependent on service regime and driving styles.
    Glen.
    Thats what I thought :wink:
    Glen
    drooby Guest
    Are you guys actually saying I can reasonably expect 640,000k's out of the Tdi?
    Surely that can't be right!
    The turbo wouldn't last that long would it? 8O 8O
    Properly maintained from new I'd like to expect 350,000 to 400,000kms out of mine, barring any component failure that cant be forseen, and at that mileage at turbo or top end rebuild would be expected in most small motors.
    Glen.
    Brisbane Australia
    I have a mate with 280k on one still seems fine original everything except belt.
    drooby Guest
    Thanks fo rthe info guys, I guess I can rest assured that the Tdi will keep on going for a while yet!
    How often do you guys recommend for oil changes? 5,000 k's?
    May 2002
    Sydney, Australia
    in a TDI I would stick to 5,000 km or there abouts - always use a good quality oil like Penrite HPR 15/40 and Coopers filters if you can get them.
    LRH
    Disco 4 SDV6 Auto
    RRC 300 TDI Auto
    Subaru GDA WRX
    Yamaha TTR250
    May 2002
    Sydney, Australia
    also every other service change the fuel filter (again recommend Coopers) and clean out the sedimetor.
    HTH
    LRH
    Disco 4 SDV6 Auto
    RRC 300 TDI Auto
    Subaru GDA WRX
    Yamaha TTR250
