24th June 2005, 11:01 AM
Continuous air for TD5
Hi all,
I am playing around with the idea of fitting a second air compressor to my TD5, I do not have ACE fitted so there is the possibility that I can utilise this spot. Could someone with a TD5 with ACE please measure the distance from the centre of the A/C pulley to the centre of the ACE pulley and also the ACE pulley diameter. If I work with these dimensions a serpentine belt for a vehicle with ACE should be the correct length. Thanks in advance.
Bruce
24th June 2005, 07:43 PM
<span style="color:blue">now this im very interested in......
there is not much room under the bonnet at all......
i was starting to think it would be easier to use the PTO to run a compressor....</span>
