this is for those of you who are project merchants. I know there are a few out there.
I was in at the tender centre at Lismore today and sitting in the yard is a 1976(?) LWB L/R. yellow/white. It has a holden motor ( 202?), is unregistered,It strats and drives, according to teh note on it. has rust in the bit at the back of the frame ( where the towbar bolts to, the bit where there is a hole for a drive shaft, don't know what its called.) I put my finger through it.
Oils leaks and so on, looks as if it has spent some time near the ocean. warn selectro hubs , 4 speed, the hard top looks ok so does the tray.
I don't know if it is avaialble for online tender.
the website is www.tender.net.au
the phone no. for lismore centre is 02-66220466
Personally if I had the time and didn't have the HZ I want to do up, I would offer about 500 for it, but then I don't know what it is worth.
john
