Air Suspension - slow air leak
					I have a problem with the car lowering over a period of time in the garage - it is also showing a dash light warning of suspension fault on longer drives - the compressor can be heard to run at odd times.
I have had the front suspension balance (left right) control valve replaced for the suspension. There were no other apparent leaks under workshop tests.
But this has not rectified the problem, So I removed the fuse over the last couple of days and the result has been a slow lowering of all bags at approximately the same rate @ 35mm lower in 24 hours (within 5 mm).
My question is:
What is the most likely culprit in this situation ?
My Guess (logically) is a slow leak in the Main Air Compressor tank fittings - it would be unlikely to be the holding tank itself, but I would suspect that there is a hole in a line or a seal that is allowing a drop in the pressure in the main tank?
Am I on the right track?
Your thoughts please?
Many Thanks
Steve
				D3 2005 4.4 V8 HSE java Black.Alpine Roof,Alpaca Leather 7seat,LRSat Nav,E diff,Bi Xenon.Hi-Ice et.voice control.Bluetooth Phone.Kaymar rearbar.Roofrails and Racks.18rims.Traxide Dual Battery towpoint Anderson plug. Xenon 4300k Hbeam.10wled450lightbar.
