Page 1 of 10 123 ... LastLast
Results 1 to 10 of 99
Thread: DonDownUnder's D3 dropping into Limp Mode
    Incisor received this via PM tonight and has asked it be posted up.
    Any help appreciated.
    Quote Originally Posted by DonDownunder
    Hi, I am travelling with a 3300kg Caravan towing with a Disco3 v6 TD01/2008. Have had a lot of trouble with falling into limp mode in Outback QLD whilst sharing the skinny roads with Road trains and many times suddenly I stop, very unsafe and I can't ask a question on the forum. Very Sad when you need help, We are from outer west Sydney, long way to go, hope we make it. Fault codes via my Blackbox Nano :
    'Any Clues please , Could a batch of bad fuel cause this?? Thanks
    FAULT 1 OF 13
    ECU: Instrument Pack
    CODE:U0010
    Medium speed CAN communication bus
    (HISTORIC)
    FAULT 2 OF 13
    CODE:U0132
    Lost communication with ride level ctrl module / Lost communication with suspension ctrl module A
    (PENDING)
    FAULT 3 OF 13
    CODE:U0184
    Lost communication with audio unit
    (PERMANENT)
    FAULT 4 OF 13
    ECU: Engine Management
    CODE:P0087
    Fuel rail/system pressure - too low
    (INTERMITTENT)
    FAULT 5 OF 13
    CODE:P0405
    Exhaust gas recirculation sensor A - circuit low
    (INTERMITTENT)
    FAULT 6 OF 13
    CODE:P000E
    Fuel volume regulator control exceeded learning limit
    (INTERMITTENT)
    FAULT 7 OF 13
    ECU: Automatic Gearbox
    CODE:U2023
    Control module network signal calibration data
    (INTERMITTENT)
    FAULT 8 OF 13
    ECU: Parking Brake
    CODE:U0100
    Lost communication with engine control module/powertrain control module 'A'
    (INTERMITTENT)
    FAULT 9 OF 13
    ECU: Ride Level
    CODE:U0416
    Invalid data received from vehicle dynamics control module
    (PENDING)
    FAULT 10 OF 13
    ECU: ABS system
    CODE:U0401
    Invalid data received from engine control module/powertrain control module
    (HISTORIC)
    FAULT 11 OF 13
    ECU: All Terrain Control
    CODE:U0401
    (HISTORIC)
    FAULT 12 OF 13
    CODE:U0402
    Invalid data received from transmission control module
    (HISTORIC)
    FAULT 13 OF 13
    CODE:U0416
    Williams West Aust
    Calling Mr Sniegy.
    Expertise requiered here.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Jul 2009
    Another D3 Owner Out On The Road Needs Assistance.
    Incisor received this email earlier today, that I have just cut and pasted here, Ron then put it up in the Breakdown section. Given the D3/4/RRS section has the most knowledgeable people on late model Disco issues I thought it might also be good have Don's email listed here as well.
    If anyone has any ideas on what might be wrong with Don's D3 and how he might fix it that would be appreciated.
    FAULT 1 OF 13
    CODE:U0010
    (HISTORIC)
    FAULT 2 OF 13
    CODE:U0132
    (PENDING)
    FAULT 3 OF 13
    CODE:U0184
    (PERMANENT)
    FAULT 4 OF 13
    CODE:P0087
    (INTERMITTENT)
    FAULT 5 OF 13
    CODE:P0405
    (INTERMITTENT)
    FAULT 6 OF 13
    CODE:P000E
    (INTERMITTENT)
    FAULT 7 OF 13
    CODE:U2023
    (INTERMITTENT)
    FAULT 8 OF 13
    ECU: Parking Brake
    CODE:U0100
    (INTERMITTENT)
    FAULT 9 OF 13
    ECU: Ride Level
    CODE:U0416
    (PENDING)
    FAULT 10 OF 13
    ECU: ABS system
    CODE:U0401
    (HISTORIC)
    FAULT 11 OF 13
    CODE:U0401
    (HISTORIC)
    FAULT 12 OF 13
    CODE:U0402
    (HISTORIC)
    FAULT 13 OF 13
    CODE:U0416
    Terry
    D1 V8 (Gone)
    D2a HSE V8 (Gone)
    D3 HSE TDV6 (Unfortunately Gone)
    D4 V8
    Williams West Aust
    I have sent Sniegy a PM alerting him to the thread.Ron does Dondownunder know his PM is here???
    Andrew
    Sep 2012
    Adelaide Hills
    sounds like a bad ground to me.
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    NSW SW Slopes
    What faults return soon after clearing all faults?
    Ean Austral Guest
    My guess is the intermittent faults are the one's returning. Am wondering if an earth fault can cause some of these, but its not something I have dealt with before.
    Cheers Ean
    NSW SW Slopes
    Hopefully only a connection somewhere around the battery shaken loose by the frequent ventures off the bitumen.
    90 Rangie Guest
    Has he done the basic checks ?
    I.E. brake lights are O.K.
    Brake light switch.
    Hard reset.
    When is it happening under hard axcelleration, any time ?
    If he is carrying spare fuel filter just change it anyway just in case.
    Ean Austral Guest
    Think if its happening pulling on and off the bitumen then it would seem to point to a loose connection of some sort , battery negative or earth.
    Cheers Ean
