Results 1 to 6 of 6
Thread: 1996 discovery 300 tdi automatic
    Gazz Guest
    I am looking at one here in Vic with 166k's it has twin airbags and ABS. The vehilce has service history but last 80k's via mobile mechanic. How do I tell whether cam belt has been changed or upgrade kit fitted.
    Also is the Auto a better/stronger proposition than a manual, Ive heard manuals can be a bit troublesome. It will do most driving in MLB metro area with stints in the bush say once a month. I will not be towing any caravans, boats etc.
    Any other issues ie ABS faults, 300 reliability at these K's etc. Can you also fit an aftermarket Bullbar to the airbag model and which is recommended?
    Gazz
    Lindsay Guest
    your disco
    I would talk to the servicer or previous owner to answer q's about what has been done to the car. There should be a yellow paint mark on the top? of the timing cover if the timing belt kit has been done by a landrover dealer I think. If in doubt, it would be wise to inspect the belt as at 166k it just might be due for another. The auto's are a good strong box if looked after and should give 250k or more without too much trouble. YOu can get airbag compatible bars for them I would talk to ARB about that.
    hopefully of some help.
    Frenchy
    May 2002
    Sydney, Australia
    with any 300 TDI that you dont know personally the history I would be changing the cam belt soon. The job can be done for about $300.
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    May 2002
    Sydney, Australia
    BTW - best combination in my opinion, Disco 1 300 TDI with Auto.
    I had a 1996 TDI Auto and wished I had never sold it.
    LRH
    Disco 4 SDV6 Auto
    RRC 300 TDI Auto
    Subaru GDA WRX
    Yamaha TTR250
    Hobes Guest
    LRH
    I'll plead ignorance....
    ummm the cam belt is the same as the timing belt no?
    May 2002
    Sydney, Australia
    Sorry, cam belt / timing belt same thing.
    LRH
    Disco 4 SDV6 Auto
    RRC 300 TDI Auto
    Subaru GDA WRX
    Yamaha TTR250
