Results 1 to 10 of 14
Thread: Bloody drivers side rear door lock.
    drooby Guest
    Our rear driver's side door in our 97 Tdi is playing up.
    When you hit the button to open the doors this door's button only comes up half way. So when you go to open it it catches and will not open.
    Is there a fix for this?
    I thought I would ask first before I started pulling the door trim off!
    Upwey, VIC
    usually the spring in the door lock mechanism, either replace the mechanism at $150 a pop or get the replacement spring at $25 a pop.
    Matt.
    Toowoomba QLD.
    From memory on my old TDi, the door lock solenoid was the issue. I got a generic one from AutoBarn. No mods required. My car had also had the anti-rust treatment and on hot days things gummed up. Even the key locks got sticky. The clowns that sprayed it got the stuff every where.
    cheers,
    Trev.
    Forty minutes closer to the hills in a house the bank is kind enough to let me live in
    Drew,
    The back door actuator in mine started to play up and I bought a Jaycar replacement motor. The problem with that was that it worked BACKWARDS - half a step out of phase with the other doors so when everything was meant to lock it unlocked and VV. The original still tried to work and it would unlock nicely, but it didn't have enough oomph to relock the lock.
    If you want to have a play with the Jaycar one you're more than welcome, but I ended up just buying another s/h original one from Toorak Tractor in Braeside for $45.
    SYDNEY -in the shire.....
    all you had to do was reverse the wires.....then it would be in phase with the others.....
    WRONG! Did that and no go. It would wait a cycle and then continue working in reverse.
    <span style="color:darkred">how many wires on the genuine and the non genuine?</span>
    Just the two. They are both slave units. Had me bahooned too!
    Gold Coast, QLD
    for sum reason completely unknown to me My passenger side door cant be opened from the out side :?
    [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img]
    I rule!!!
    2.4" of Pure FURY!!!
    The Dandenong Ranges / Mount Dandenong
    Is that window tiniting legal [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
