I would replace the crankshaft position sensor because some of the symptoms are typical of a failing one and its a sensor that hasn't been replaced. You could try cooling the sensor with an aerosol or water spray to see if the problem is quickly overcome.
					 LR3 2006 4.4ltr, fuel issues which Land Rover cannot diagnose
  Reply With Quote Originally Posted by shedlock2000
