Results 1 to 8 of 8
Thread: Gaskets
    May 2015
    Victoria
    Gaskets
    I have purchased Loctite No4 gasket cement. Is this ok to use on my 95 gems 4.6?
    Mar 2010
    x
    Coz you've already bought it, I'm gunna say yep.
    Depends where you are using it. I use No.4 Aviation Gasket Cement for a number of applications.
    May 2015
    Victoria
    Is it ok to use it on head gaskets and intake manifold?
    I wouldn't use it on the head gasket and probably not on the inlet manifold.
    May 2015
    Victoria
    Thanks Ron,
    You are always helpful. What type do you recommend?
    Crafers West South Australia
    Gaskets with sealant supplied by the factory, ie head gaskets, inlet manifold gaskets, anything with raised silicone lines etc should not need any extra gasket goo. I'd only use it for such things as thermosat housings, water pumps with plain paper gaskets or the plenum top part of the manifold.
    Jan 2012
    Bendigo
    The only joints on a gems that require a sealant is the sump and upper to lower inlet manifold facing.
    Sent from my SM-G900I using AULRO mobile app
