Results 1 to 10 of 13
Thread: Popped the same Eas bag again
    Aug 2014
    Echuca
    Hi guys,
    I've popped a couple of bags off the bead when off roading, when getting a bit fairdinkum and a bit of wheel travel happening, the rear right has seperated from the plastic bottom mounting cone.
    It's been on the rear right both times, 2 different bags. They obviously get on an angle when the rear axle is a full travel, but the right goes too far and has seperated...
    Any ideas on why it would be the same corner? Coincidence? Failing shocker? Bad luck?
    Sorry if there's info in another thread...
    Mark
    May 2010
    Mindarie, Western Australia
    Mark
    Have you changed heights from stock or changed shocks from the standard boge?
    Gary
    2007 Range Rover Sport TDV8
    Modified 1996 p38a HSE sold
    Aug 2014
    Echuca
    Gary,
    No, I haven changed anything, I've recently checked and slightly adjusted the heights to recommended, I don't know if a previous owner has changed shocks though.. Anyway of checking? These ones don't appear to be branded.. All shockers seems to behave perfectly
    Mark
    May 2010
    Mark
    The Boge (OEM) are not the most exciting looking shock just a plain black and from memory no identification on them. Sorry it's been a while since I ran standard length shocks. Someone else with stock suspension may be able to assist better here .
    Gary
    Feb 2010
    Townsville, QLD
    I had the same problem with my blue P38 on standard shocks. I think it's just a geometry issue. My bags were Gen III's that separated. Right rear each time.
    Aug 2014
    Echuca
    Yeah plain black they are.
    thinkinh I might try and change the angle of the bottom mount some how, so that at full travel it doesn't peel off and that edge, may help
    Next question, how to re seat that bag, it's only a year old.....
    Feb 2010
    Townsville, QLD
    KY and patience!
    Aug 2014
    Echuca
    I would've thought lubrication would only assist in it separating again? I have had a look at install notes and obviously people use different things like soapy water, etc but concerned of simply popping it off again next time I hit a decent sand dune..
    May 2010
    Mark and Keith
    Just out of curiosity do you recall what height setting you were on when the bag popped?
    Gary
    Aug 2014
    Echuca
    Gary,
    I was at standard height
    Mark
