Results 1 to 8 of 8
Thread: SPEED LOCKING
    Mar 2009
    maryborough qld
    SPEED LOCKING
    The speed locking only works sometime,well most of the time not,anyone had this and what to check,do not have any diagnostic gear as yet.Cheers.
    Feb 2014
    Quote Originally Posted by rangietragic View Post
    ....cruise control?
    Mar 2009
    maryborough qld
    Quote Originally Posted by chaybra View Post
    ....cruise control?
    Have rarely used cruise,don't know how it would tie in, but it is a Land Rover product so anything's possible.Don't really miss it but when it isn't working the drivers door doesn't unlock with the remote.Only thought of it because it started working again monday,not today though.
    Mar 2013
    Gymea
    I'm guessing you mean door locking/unlocking.
    Not speed locking?
    Aug 2010
    Sunbury, VIC
    He means the doors automatically locking when you drive off and reach a certain speed.
    I disabled it on mine as it proved to be a PITA. When you stop you have to manually unlock the doors - which I always forgot to do...
    Feb 2014
    This makes more sense, I honestly didnt know the ffrr had this function. Mine must be broken/disabled.
    Mar 2009
    maryborough qld
    Quote Originally Posted by bacicat View Post
    Only issue i have with it not working is i have to use the key to open drivers door,others unlock which makes me think maybe crook door lock.Have replaced pass. door lock ages ago.Got sick of people crawling over the console.
    Jul 2015
    Sydney, Australia
    What year is the L322 in question?
    There is a procedure that works on Jags & other models from the Ford era to disable the driveaway locking function, maybe it works on a >2006 L322 as well?
    Turn on the ignition so all the dash lights come on but don't start the engine.
    Lock the door using the locking lever on the door handle and then unlock the door (but don't open it) 3 times.
    Turn off the ignition.
    Turn on the ignition but dont start the engine - you should be able to hear a beep.
    Lock the door again as before then unlock it (only once this time) - a final beep should be heard.
    Worth a shot I guess...
    2009 Range Rover Sport 3.6L TDV8
    2017 Jaguar XE R-Sport
    Supercharged
    Jags XKR & XJR 4.2L S/C
    Old Jaguar Australia - www.facebook.com/oldjaguarau
    Upgrades and retrofits for late model Land Rover and Jaguar vehicles. www.oldjaguar.com
