Results 1 to 6 of 6
Thread: Sliders for a 2 Door RR
    SAFETY BEACH Victoria
    Hi
    Has any body made there own rock sliders for a 2 Door RR :?:
    was thinking of using some 50 x 50 x 6 RHS but don't now how to fit them
    any ideas
    Jul 2003
    Hi Kai,
    discowhite made some for his Disco (4dr):
    http://www.aulro.com/modules.php?name=Foru...t=sliders#86450
    The fixings would be similar in principle to the RR
    You could PM him if he doesn't pickup this thread. [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    Mahn England
    Ex 300Tdi Disco:
    RR5L Guest
    Re: Sliders for a 2 Door RR
    Originally posted by kaistuff
    Hi
    any ideas
    Hey Kai,
    I reckon 6mm WT might be a lil too heavy duty! How about 3mm?
    Box Hill, Victoria
    Originally posted by RobG65+--><div class='quotetop'>QUOTE(RobG65)</div><div class='quotemain'><!--QuoteBegin-kaistuff
    Hi
    any ideas
    Hey Kai,
    I reckon 6mm WT might be a lil too heavy duty! How about 3mm?[/b][/quote]
    I think 3mm would be fine, especially being box.
    I used 4mm just for the sake of it as it was lying around.
    Dave.
    Padstow NSW
    i think i used 4mm box, dont use anything lighter.
    it is welded to 75x100x5 angle and the tube is heavy wall 28nb pipe
    make sure you prep all the areas that you weld first, get a good
    weld in there and they will be a stronger than anything on the market.
    things to note, the bottom door line in a disco isnt straight its curved.
    i cut and shut the box to suit the door line.
    and there is a bump you need to go around, at the b pillar.
    Originally posted by DaveS3+--><div class='quotetop'>QUOTE(DaveS3)</div><div class='quotemain'>
    Originally posted by RobG65+--><div class='quotetop'>QUOTE(RobG65)</div><div class='quotemain'><!--QuoteBegin-kaistuff@
    Hi
    any ideas
    Hey Kai,
    Dave.[/b][/quote]
    i wil use 6mm as i have some at work just lying around :wink:
    <!--QuoteBegin-discowhite
    [/quote]
    nice job
    But i am not sure if i can fix them the same Way on the 79 RR
    if i remove the plastic strip under the door there is a 45mm recess and then a 50mm drop wonder iv that section is strong enough to hold the car?
    must have a better look under the car tomorrow
    thanks so far for your help
