Thread: BUGGER BUGGER
    Jul 2015
    Mount gambier
    Angry BUGGER BUGGER
    Hey people question just fitted up a double din pioneer stereo works great look awsome BUT no more clock on the dash anyone had this can I get it back
    Thanks in advance
    On a Positive note had to change out a globe wow how easy to change out headlight globes
    Cheers Dave
    Can't help you with clock but search the forum as there's a few threads on the issue. How about some pics of your install?
    Ean Austral Guest
    it seems that from everything I have read, both here and the UK site, if you change out the base model stereo for a non genuine unit the clock is lost.
    I had to change the park globe on mine and you have to pull out the whole light assembly , easy enough till 1 of the plastic clips decides it wants to brake .... hasn't happened yet , but , heat from the engine bay means it will only be a matter of time me thinks.
    Cheers Ean
    Jul 2015
    Mount gambier
    Yep will post up pics
    Headlight has like sliding locks easy as
    Keys tested battery's ok
    Start car ok
    Won't lock or unlock
    Heeeeellllpppppp
    Dec 2008
    Prospect 2148
    As far as the clock goes, yes if you change out the standard radio, then no clock, since it is run from the radio. No big deal eventually you won't even notice it is missing. And you'll have a much better radio.
    As far as the battery goes, is it only the keys that won't lock /unlock remotely? Have you tried using the central locking buttons on the dash?
    Mike
    Jul 2015
    Mount gambier
    Quote Originally Posted by rocmic View Post
    Mike
    Yep that's it mike just the keys won't lock the vehicle and the dash lock works fine if I pull one key apart and put it back together it works for a while it must be something electronic any thoughts someone else has proberly had the issue
    Cheers Dave
    Jul 2015
    Mount gambier
    NEW DOUBLE DIN PIC
    WELL SEE IF THIS WORKS
