Results 1 to 10 of 20
Thread: Where might the oil filter be on a Diesel?
    Melbourne, Australia
    I changed my oil on the D3 tonight and wanted to replace the oil filter as well but I could not find the oil filter 8O
    The filter is a cartridge type. All you get is a paper element which must drop into some kind of canister.
    This is first time I've changed oil on a diesel so is it normal not find the filter on the motor?
    I dropped the bash plate off from underneath and undid the sump plug (which doesn't use a washer to seal but uses a rubber O-ring to seal) and could not find the filter anywhere around the engine. I thought maybe it is remote from the engine but didn't drop off all of the other covers under the gerabox or under the radiator.
    Any hints where it might be?
    Thanks,
    Chris
    Jul 2003
    PCH,
    You are breaking new ground here. [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    You could try a PM to Defute. He has "inside" knowledge :wink:
    Drivesafe's RR might be similar.
    Mahn England
    Ex 300Tdi Disco:
    Warburton, Victoria
    This might not help, but give it a shot.
    i had a 2001 model Volvo, the filter was paper in a canister that i could not find for the love of god.... but then i was showed and it was simple really.....
    Remote Filter.
    Call LR in the morning.
    WOLLAPIT85 Guest
    Defute will know for sure.
    SYDNEY -in the shire.....
    <span style="color:blue">got any underbonnet pics of the engine we could look at....
    it shouldnt be that hard to find......mine has one hidden next to the turbo...</span>
    I couldn't see anything around the engine that vaguely looked like a filter. Its very tight around the engine and if its near the turbo I don't know how you'd get to it. Under the plastic cover which sits on top of the engine there is a plastic canister near the fire wall but it is very hard to get to and it has some kind of lid on it but it isn't big enough for the filter to fit into.
    I bought the filter from Lance Dixon in Ferntree Gully and they haven't even used one yet and didn't know what the sump plug washer code was (I found out it doesn't use a washer, the plug has a rubber o-ring). I'll ask my dealer MLR where the filter is hiding so next time I do the oil I'll know where to look.
    I haven't looked near the transmisson because there is a cover under it and I was getting a bit lazy last night. I'm sure it must be easily accessible. I just haven't spotted it yet 8O .
    Chris
    South Yundreup,WA.
    It should be in you vehicle handbook.
    Bathurst NSW
    Was about to say the same thing. Is there anywhere on the net you can look? Matt
    <a href=https://the4wdzone.com.au/wp-content/uploads/logo.png target=_blank>https://the4wdzone.com.au/wp-content/uploads/logo.png</a>
    The 4wd Zone/Opposite Lock Bathurst
    263 Stewart Street, Bathurst, NSW
    http://www.the4wdzone.com.au/
    Discounts for AULRO members, just shoot me a PM before you purchase.
    Oct 2003
    Montrose, Vic.
    G'day PCH
    Like the other guys - can't give you a definite answer --- but I suspect remote filter is likely.
    Maybe try a post here...
    http://disco3.web-rover.co.uk/forum/
    After all the POMs have had them for longer than us... so someone must have changed an oil filter by now 8O
    Hope that helps,
    Mark
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    Tregeagle, NSW
    Best of luck, I looked under the bonnet of a D3 recently and it is a wonder you could find anything with all the covers.
    On a more postive and brighter note,as I have worked out Landrover owners are a breed to themselves, different , not remote, helpful and polite. ( Hatchy take note) After all who else would change the oil and filter on a brand new release vehicle.
    john
