Results 1 to 3 of 3
Thread: Lack of power
    Tonybankrobba Guest
    Lack of power
    Hi , iv just had an alternator fitted, works fine but now iv got no power until 2000 rpm, iv checked hoses etc but just don't have any low down power, it's all good after 2000 , cheers
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    I doubt it has anything directly to do with the alternator. However, check that the fitting of the alternator has not unintentionally disconnected the vacuum line to the distributor, which would affect timing and also give a manifold leak.
    There are other possibilities, but perhaps the most likely is an ignition timing problem, or possibly a partly blocked jet in the carburettor, or even the carburettor flooding. If it is a Zenith, check the mating surfaces of the top cover for flatness.
    Tonybankrobba Guest
    Thanks john
