Results 1 to 3 of 3
Thread: D3 Drivers headlight flicker
    Stevie Guest
    Hi Guys
    My drivers headlight is flickering with only 10-20% light available at best sometimes nothing. Any ideas on what and where I should look...it seems like a loose connection? It's a D3 4L V6 if that helps
    Cheers Stevie
    Mar 2007
    South Arm, Tasmania
    Probably a bad earth connection.
    I'd start by pulling the plug off the back of the light, spray all the contacts with lectra clean or similar, allow to dry and then re-connect.
    Cheers .........
    BMKAL
    Stevie Guest
    Thanks BMKal...first job in the morning
