Results 1 to 10 of 12
Thread: Charging D4 battery when camping
    Mar 2014
    G'day,
    I have only recently upgraded to the D4 and during a trip to the Big Red Bash I experienced the low battery warning - being stationary for 2 days camping at Big Red.
    I ran the engine for 45 min and all was OK. Just did a search and realised that the discharging issue of the D4 seems to be common...
    Question I have though - I do have an Anderson plug at the back of the car to charge the Camper when travelling which is wired directly to the battery terminals (fused, but no isolator). I usually travel with a solar panel - can I connect the solar panel to the Anderson plug to charge the battery when stationary? I asked LR, but have so far not been able to get a straight answer.
    Any thoughts?
    Thanks.
    Quote Originally Posted by theins View Post
    ... can I connect the solar panel to the Anderson plug to charge the battery when stationary?
    Provided you have a solar charge regulator between the panel and the rear Anderson plug then yes.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    NSW Far South Coast
    (which is wired directly to the battery terminals (fused, but no isolator))
    If this is correct, it is the wrong way to wire anything in a D3, presumably a D4 as well.
    Nothing should be connected to the negative terminal of the starting battery as it upsets the battery monitoring sensor.
    On my recent big trip I met a guy in Kakadu in a D3 who had troubles with his aux battery system. He was left with not enough charge to start the car and all batteries being very low.
    He had an isolator system (which consisted of 3 boxes) and it was wired to both battery terminals. I tried to get him to remove the wire from the terminal and relocate it to an earth stud.
    He wouldn't do it because he wanted to wait till he got to Darwin to ask the dealer.
    Oh well you can only try.
    He said the 3 box system was a DC-DC system which has worked well for years on previous trips.
    But when quizzed it appears previous trips were across the Simpson where he would drive for many hours at a time.
    This trip was basically an hour or so driving then camping overnight so the batteries never got a chance to fully charge, (would have been better being charged direct from the alternator ala Traxide.)
    I have a Traxide system and had NO problems with my batteries being charged even though I was travelling the same way as him.
    Mandurah WA
    I have a Traxide dual battery system in my D4 and have often charged the batteries using a mains charger connected through the anderson plug.
    When camping over a couple of days my intention is to use a solar panel mounted on the roof rack to provide charging, via a regulator and 12s plug, connected to the white trailer plug[pin3 earth/pin4 positive] and the anderson plug to power lights etc.AFAIK this should be ok.Tim your valued opinion?
    Queensland
    Mar 2014
    Quote Originally Posted by ytt105 View Post
    Well, I had LR install the Anderson plug at the rear of the car. I will open the battery box and have a look how they connected the leads...
    And yes, I do have regulators on the panels (1 at 100W, the other 140W).
    I do not have a dual battery system in the car.
    Oct 2014
    Something to consider .... if you want to run both panels at the same time I believe you'll need to go through a single regulator, which will need sufficient capacity to handle the amps coming from both panels.
    You don't want a setup where the regulators fight each other.
    Regards,
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Mar 2014
    Quote Originally Posted by LRD414 View Post
    Regards,
    I am not particularly experienced in car electrics - hence would not consider connecting both at the same time - would always be either or....
    Queensland
    Hi Scott and theins, you can run two separate solar setups through two different solar regs and have then connected to a common point, like the terminals of a single battery.
    If the battery is low and the sun is high, both panels will supply what they can.
    Once the battery best near a full charged state, the solar reg with the lowest maximum ( simplified statement ) voltage setting, will simply turn off ( usually by going into float mode ) while the other will continue to charge the battery until it too goes into float mode.
    This is no different to having a battery charger and a solar reg connected to the same battery, and this is a VERY common type of setup.
    Oct 2014
    ?...you can run two separate solar setups through two different solar regs and have then connected to a common point, like the terminals of a single battery...
    Thanks Tim. So could the common point be the rear Anderson plug that's connected to a Traxide system aux battery? Using a 2 into 1 piggyback cable?
    D3 2005 V8 Petrol
